I'm in a project where the spec says the connections to DDC through Lon Bus & the supplier offering two options either Panel Bus or Lone Bus, also the supplier recommending to use the Panel Bus where the DDC is the same type for both cases, i don't know what is the best option for me? taking into account the connection on the high level through BacNet IP. Thanks in advance.
