S stew Senior Member Location federal way,washington Jun 21, 2004 #1 Cant locate the code section that gives the minimum clearance a panel must be when mounted on a backboard.
S stew Senior Member Location federal way,washington Jun 21, 2004 #3 Re: panel clearance sorry bob I was not clear enuf in my post I meant the airspace requirement between the panel and the backboard.
S stew Senior Member Location federal way,washington Jun 21, 2004 #5 Re: panel clearance Ryan where did I see in the code a .625" requirement?
ryan_618 Senior Member Location Salt Lake City, Utah Jun 21, 2004 #6 Re: panel clearance I can't think of ever seeing that in the code, Stew. That doesn't mean its not there though. The only requirement I can think of is the 1/4" fir wet locations, in the aforementioned section.
S sdbob Senior Member Jun 21, 2004 #7 Re: panel clearance edit: never mind, I thought you might be thinking about a NEMA recommedation but I can't find that either... [ June 21, 2004, 06:39 PM: Message edited by: sdbob ]
