kevin458
- Bloomington,MN,USA
I am not able to find which NEC rule addresses the size of conductor feeding the panel-board. I think for 3-phase panel-boards with mostly lightning loads, the ampacity of phase conductors should be 125% the rating of the main bus of the panel-board, and the neutral conductor should be 200% the rating of the main bus of panel-board. What do you guys think? Thanks.
