I'm having trouble understanding how to apply some of the Section 250 tables/terminology to my design. I am installing a panel on the deck of a refrigeration equipment trailer where a generator is also installed nearby. The feeder from the generator enters the panel through some LB conduit, where I am running a few branch circuits for compressors and a condenser, which are the vast majority of the load. The ground on the generator is jumped to the neutral at the generator. I am not using 277V anywhere in my design and haven't needed neutral. My questions are:
1.) Is there code requiring that I run the neutral conductor to the panel, in similar fashion to the ungrounded conductors (power distribution lugs, in my case)
2.) Are the notes in the following diagram (attached) sufficient assumptions in how I should apply the conductor sizing requirement tables?
Thanks,
Thanks,
