joeyww12000
- Chatsworth GA
I have a EDP with an 8 inch trough attached to side with Emergency panel above it. The trough has two 2 inch nipples going into the emergency panel, the 3 hot legs and ground go through one and the neutral is in the other. Is there anything against code here? All the circuits for the panel also are coming through the 2 2 inch nipples.
