1793
- Louisville, Kentucky
- Inspector
I asked how many spaces are "main" spaces because if it has the usual 12 poles for mains (which gives you six disconnects if they are all double pole breakers) there would only be 4 poles left for the lighting section (not counting tandem handles)It is definitly a split buss but using the twin or tandum breakers make this illegal due to the six disco rule, and any home inspector will or should pick this up. A panel upgrade is definitly in their future.
I'm pretty sure that's just a subpanel and so the six disconnect rule would not apply as long as there is a main at the meter section.
I would guess the the two upper breakers feed a A/C and and an oven or some bigger load. I don't believe that they are being used as main breakers.
