bure961
- Farmingham, MA
I need some help with something I should already know but I am not certain of the answer. We purchased a home out of state and a short time later decided I needed a receptical in the garage. After removing the cover to the 200 amp panel I notice the bonding screw was installed in the panel [will be removed]. There is a sub panel outside for the pool equipment[inground] which is feed with a 4 wire cable no main breaker in sub, 2 phase conductors 1 neutral 1 equipment ground bonded in sub panel.
All the ground wires and neutral wires are on same neutral bar in main panel.
My question is should all the bonds and neutrals be seperate in main panel and the egc and neutral be seperate in main panel ?
Thank you
Thank you
