Brandon Loyd
I have an existing panel with an equipment ground landed on the neutral bus bar.  There are no neutrals in this panel as they are all motor loads.  There is one other branch circuit ground landed on the neutral bus bar.  But there is no bonding jumper to the panel can.  Don't you always have to bond at least one ground the any metal enclosure if it passes through, with the exception of isolated grounds?
