residental panel....200 amp main....20 circuit...has 11 piggyback breakers and 4 two pole breakers...customer wants a subpanel...adding a 50 amp load via hot tub! able to redirect wiring to subpanel and free up space for another 2 pole breaker in main panel. Question: label on main panel states "AC 1 phase 3 wire 150 amp" Main breaker is 200 amp...cable from meter to panel is 4/0 alum...could the main breaker have gone bad and been replaced with a larger amperage breaker...or did someone just replace the guts with an upgrade and use the same can...neglecting to replace the label? homeowner has no idea about upgrade! House has 2100 sq. ft. of living space...2 heat/air units...elec stove...water heater...etc. panel id: gould..GQ16MBA..I-T-E..Indoor load center...breaker id: ITE 4-pole...EQ-9483 200amp
anyone ever run across this?
