I am repairing a job where the original "electrician" seemed to have very little understanding of the code. The newest problem I found is a panel ( Home line 100 amp ) was installed in the attic where the highest point is less then 5 ft and slopes down from there. There is less then 28'' in front of the panel and the surface you stand on is ceiling joists 16'' on center. To get to the panel you need to go through a hatch in the master closet with a 10 ft ceiling. To boot the HO doesn't even own a ladder. I had to call another subcontractor that was on the job when it was built to find the panel.
So my question is would you relocate the panel ? to do so would be a real PITA. or would you leave it where it is at ? Mechanically it is safe but you can not service it or reset a tripped breaker without a ladder. The house is less then 3 years old.
