Cannot answer your question without knowing what supplies the second panel...???There is a building that already is being feed from another building. There a ground rod at the seprate building and the existing panel is grounded with a #6. Can the second panel bug onto the the existing ground wire? If so what size wire it is a 200 amp panel.
You don't need a ground rod to the second sub panel in the same structureNo i'm asking can two sub panles that are feed from a separaet building share the same ground rod.
Actually I missed one possibility... both panels are fed by the same feeder.No i'm asking can two sub panles that are feed from a separaet building share the same ground rod.
