Hi All:
I'm new. Hopefully I only have one question. I am framing out a basement. The panel is located at the back door along with a whole short wall of other electronic, alarm, vonage, ISP, wireless STUFF. The area is ~4' X 5' and the panel is on the right side wall. Everything hangs off the wall. Rather than finishing behind all this stuff, can I frame out a foot from this wall, installing a large bi-fold door in front of panel? Clearance with doors open would be code (36" to front, 30" across front), clearance with doors closed would be 14" to the front, 30" across.
The thinking is that if I frame the area as one then it would create an unfinished closet ~4' X 5' and the homeowner will definitely use it as an unfinished closet and stack stuff to the ceiling in front of the panel. If I frame out a small area for the electrical and other stuff then they can't put anything in there. The area outside the electrical area would be finished and they wouldn't store anything there (good access to bi-fold doors) because it wouldn't be hidden.
Not code or code?
Thanks for any replies.
Not code or code?
