Hi All,
I am new to posting here. Just wondering what your experience is with inspectors enforcing NEC 408.4 - "every circuit and circuit modification must be legibly identified with a clear and specific purpose or use, including sufficient detail to distinguish each circuit, . . . "
I've had some inspectors say if you've done a reasonable amount of work in the house (like a kitchen remodel) they expect you to ID and label ALL circuits in the entire panel. If you are working in an older house with multiple generations of wiring/changes/additions, this can be time consuming. Other inspectors are not so hot on this requirement. They just expect labeling on the circuits you touched. So I'm curious what you all are seeing in other parts of the country, I'm in Massachusetts. Any input is welcome. Thanks!
