dvcraven0522
- St. Louis, Missouri
- Engineer
I have a panel that has a design of 370 amperes that is calculated per the NEC demand factors. This is a main lug only panel fed from a main distribution board. Is this circuit breaker required to a 100% rated. This is for a commercial store with a kitchen and bar areas.
I assume the thinking is most CB are not to be loaded more than 80% of its rating. Although I think that has been removed from the code. Your thoughts are most appreciated.
Dan Craven
Dan Craven
