Panel placement
I am licensed Home Inspector in North Carolina. A home I inspected had a sub panel installed ON the cabinet of an air handler in the basement. Of the thousands of homes I have inspected I have never seen this done, it doesn't seem right (when the air handler is changed the panel will be hanging) but I can't find anything governing panel placement of this sort in NEC. Woud mfg recommendations cover this ( house was built in 1996) or is there somewhere in NEC that specifies equipment must be mounted on permanent backing?
thanks for whatever help you can provide
Austin
The installation instructions would give you the mounting requirements for a panel enclosure.
Welcome to the forum.:)
Chris
