Ken9876
- Jersey Shore
When replacing a panel do the breakers need to be upgraded to the AFCI type, or does this fall under a grandfather rule, this install would be in NJ
Between now and October 5, 2009, electrical plans may be submitted conforming to either the 2005 or 2008 NEC. After October 5, 2009 submitted electrical plans must conform to the 2008 NEC.
Sounds like time to call a handy-hack who will do it without the permit.
Now that is good sound advice...
Hey I don't condone it! :smile:
I am saying that it is natural that when the rules become unreasonable even good people will start trying to work around them.
No way would I stir the pot on a Sunday and then leave..
I believe that you will find the 2005 to require AFCI BEGINNING in 2008 ... in more limited areas than the 2008 code does. But that is not a comment on what is required in an upgrade.I believe AFCI protection was an option under 2005 in N. J.
Thanks for all the replies, I'll call the DCA and local building dept. Still don't know which way I want to go with this job. Old 100 A pushmatic panel, 40 year old equipment, meter pan doesn't look so great from the outside, I want to rip it all out and install a meter main and move the panel to the basement where I belive it should of been in the first place. I find it amazing the HO will spend thousands to polish a turd, but will not want to spend a penny to make their home safe.
It seems optional to me ,....Do you have an article ???3. Chapter 2 of the electrical subcode, entitled "Wiring and Protection," is amended as follows:
i. Section 210.12(B) of Article 210, entitled "Branch Circuits," is amended to insert the following sentence at the end of the section, "This requirement shall be considered optional."
Easier that way........
Back to the original question I would think you should be able to replace the panel without making the whole house 2008 code compliant.. as long as the panel install is 2008 code compliant. the attached branch circuits are not being modified until you add the AFCI breaker. they were designed and installed to another code and you are not modifing the branch circuit..all you are doing is replacing old parts with new parts and the new parts are more superior then the old parts.. JMHO..
