Panel Replacement
RB1
Does your jurisdiction require AFCI protection to be provided for a dwelling unit service/panel upgrade?
No
Unless there is renovation going on inside where the walls are opened up. Or where extending a circuit more than 6' in a required AFCI protected area.
Not unless the "branch circuit' is being extended or modified in some way itself.....and if so defer to the Exception if applicable under 210.12(B)
