Panel swap
Oakey
New Jersey
I am doing a 100 to 100 panel swap in a house. Pretty routine but someone has installed the pool bonding wire to a lug inside the panel. Traced it outside to the pool pump where it ends. It doesnt run to the frame of the above ground pool at all. Knowing that we must install the bonding wire to the pump and the pool frame...Installer did a decent job using the correct twist lock etc.
My 2 questions are:
Was this ever code ?
Should it be put back the same way or should it be changed?
Here is a pic
Thx for any advice. Pools and I dont mix...
