I agree. If resistance heat they typically have both 208 and 240 volt kw rating marked right on the unit. Compressors and blower motors are also rated 208-240 volts.
Some specific heating units may sometimes be 208 only - one I do run into on regular basis is cove heaters - manufacturer I buy has 208 and 240 volt units - both same watts for same length of unit - 208 units will not be warrantied if they are connected to 240, though you could connect a 240 volt unit to 208 - they technically may not warranty it, but it isn't all that likely to fail either since it will only run at 75% of rated wattage.
Water heaters almost always have both 208 and 240 volt rating marked on them.
Ranges and dryers often do as well.
