threephase
Can somebody reference me to the Article in the code book that deals with Panelboard minimum heights from floor as well as receptacle heights from the floor?
Thanks
Threephase
Thanks
Threephase
threephase said:SOunds good.
So is it possible that there's no exact heights here? I thought receptacles were mounted 14" from the ground and Panels were mounted 3' from the ground.
Maybe it's up to the disgression of the electrician or local codes.
Are we talking about a dwelling or a mobile homeinfinity said:Look at 550.11(A).
Bea said:Are we talking about a dwelling or a mobile home
dsteves said:Not sure about the panelboard off the cuff, but a good rule of thumb for the receps is to make 'em the same as all the other ones in the joint![]()
Dan
Of course, if you're the first one in to install 'em, you can always say you respect chaos and hang 'em wherever you like. Me, I like 12" above finished floor to the bottom of the device box.
Tallgirl, apparently in your case it might not matter on the high end of the spec... ;-)
Rockyd said:Smart shops in residential give make sure that everyone has the same length hammer handle. Then everyone can sit the hammer on the floor and set the box on the hammer. Drive that box on, no time wasted measuring.
I like 16" to the bottom of the box. Gets you to ADA compliancy, and you don't have to bend over a mile if your over six feet!
allenwayne said:I know of one builder that specs receps. 10 in to center and switches 36 in to center.
dsteves said:The jig is a good idea. I've made 'em out of 2x4 in a pinch.
Tallgirl, by random I mean no two alike. It's a real nice touch, especially along things like kitchen countertops![]()
The measurement is along the floor line for the receptacles that are required by 210.52(A)(1). Any receptacle less than 5'6" above the floor is permitted to meet this requirement.That's why I asked if putting an outlet 5' up the wall affected 210.52 (A) (1).
DesertRat said:It's kind of a pain to get everybody using the same hammer. I find it easier and just as effective to cut several lengths of pipe to recept. height, mark them "recept" in black marker and pass them out to anyone roughing in. You just have to make sure everyone is using them the same way and you don't have one guy measuring from the floor and the next guy measuring from the top of the bottom plate.
