sparkyguy545
Location: Commercial Mechanical room; single man-door entry.
Space is tight (but when when isn't it, right??).
Question: Can a 100 Amp 208Y/120 panelboard (not service entrance) be located behind the door if Article 110.26 clearances are met when the door is closed? When the Mechanical-room door is open, it would be in front of the panelboard (if this isn't obvious). However, no one would be working on the panel with the door open. Once you go into the room and close the door, you would have the minimum work-space because the door would be out of the way. If not permitted, pls site references. It just seems wrong . . . but I've been requested to put it there if I can't find a specific section that says it isn't permitted.
