panelboard loading
l_zabel
I recently have taken my electrical journeyman's test (and passed thanks to Mike's book's) and ran into a question on the test I couldn't find in the code on panelboards. The question was, Can a 200 amp panel board supply a 200 amp load? I couldn't find anything in the code that was against it so I answered yes. There is no test review in Alaska so I don't know if I got it right or wrong. I can't see any reason why you would, but can you?
charlie
Indianapolis
Re: panelboard loading
Your guess was correct. You may load all overcurrent devices to 100% of non-continuous load. Another way to look at it is to add all of your continuous loads at 125% and your non-continuous loads at 100%.
I am getting ready to go on vacation and away from my computer so someone else will have to give you the referances. :)
The views and opinions expressed herein are solely those of the author and do not necessarily represent the views of any organization.
jackmcg
Ok.. been my understanding for years that you can only load up to 80% on a circuit or conductor.... has something changed?
iwire
Massachusetts
As I understand it, a standard breaker can be loaded up to 100% non-continuous (less than 3 hours) or 80% continuous.
There are larger breakers that are rated 100% continuous, one that I have worked with is a Square D 3000 amp breaker.
Bob
