I am doing a project with 208Y/120 volt 3-phase 1200 amps service. I am thinking what kind of electrical board I can used for the power distribution system. From manufacturer's catalog, panelboard can be rated 1200 amps with 1200 amps main breaker, switchboard is rated through 4000 amps. Panelboard is definitely smaller and main breaker and branch circuit breakers are integrated into one panel. Switchboard will have at least two sections, one is main breaker section and the other is distribution section. Can I use a panelboard with 1200 amps main breaker as service disconnect means, or I have to use a switchboard? Why? What is the difference between them? How do you approach this power distribution system?
Thanks.
David
Thanks.
David
