millerjohn
- Afghanistan
I am a QC Electrical Inspector with CH2MHILL at camp Leatherneck, Afghanistan. Trying to find a refrence for sharing neutrals between panelboards fed from the same source. Situation is this: 400A main dist. panel (208/120 3PH) feeds individual rooms each with a single phase 60A sub-panel/panelboard. Neutal is shared between three phases with one phase (each) supplying (each) panelboard. Junction boxes are used to carry the neutral on to the next room. Hence, one neutral; three circuits fed from three single pole breakers; feeding three separate rooms. Should single pole breakers be grouped together and handle ties installed?
Thanks!
Thanks!
