Panels/ arc fault?
johncox
Georgia
because of arc fault req. on all electrical circuits in residential bdrms Are panels now prohibited in all residential bdrms ???
Why or Whynot???
since
Re: Panels/ arc fault?
210.12B requires all 15 and 20 amps outlets to be protected. See def of outlet.
"All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets . . ."
If the branch circuit is in a bedroom, it is not required to be protected with an AFCI device unless it feeds an outlet in the bedroom. In Indiana, that has been changed to read receptacle outlets. :D
The simple answer is that a panel does not meet the definition of "outlet" since a panel does not "take current to supply utilization equipment".
