panels
tippy
New member
i am currently re wireing my cabin in lycoming county and the local code enforcer is telling me that i do not need a main breaker in my new panel even though i do not have a disconnect between the meter base and my panel can this be correct
Re: panels
You need a disconnect somewhere. There is no rule that forbids you to have a main breaker in the service panel.
Re: panels
That's weird. My great-great-great grandfather was a cobbler in Lycoming County.
I guess no one else sees the coincidence... :D
Re: panels
It is correct IF you can deenergize the entire service with no more than "six throws of the hand."
Re: panels
Larry, I've always felt that 408.34(A) and 408.36 would prevent this. In his sitaution this would almost have to be a L&A panel (by definition)m and 408.36 restricts the main to two breakers.
Re: panels
Maybe the inspector subscribes to the theory that the meter is a disconnecting means. There are so many things wrong with this theory that I can't decide where to start, but I have heard it seriously argued.
