We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
If a paralell arc the same thing as a short circuit? So why would this not trip a standard circuit breaker? Ive read 120v paralell arcs will not arc unless actually touching. If this is the case wouldnt a standard breaker detect this?
All arcs have impedance and can limit the current flow to a level that will not cause the OCPD to open the circuit. An arcing fault is not a solid short circuit.
