NEC 2002, 310.4 regarding parallel conductors states "where run in separate raceways or cables, the raceways or cable shall have the same physical characteristics.". I have a situation where one of the paralleled pvc conduits requires a small section of flexible metal conduit to enter a switchboard. Does this imply that all conduits should have a similar section of flexible metal conduit to match --or none of the conduits should have any metal conduit --since metal is not pvc.
