frankft2000
- Maine
A customer is putting in a manufactured home 500' from the transformer. The meter location that they currently have is about 175' from the transformer fed with overhead wires. The power company handbook states for voltage drop, this application would require parallel 4/0's. the service will be a 200 amp service. on the home end since the load center comes installed I guess my best bet is to bring the parallel conductors into a j box then tap down to a single 4/0 entering the load center. This would look pretty ugly doing the same thing on the meter pedestal/pole. The customer does not want the power company to set a new pole with a transformer closer to the home. So my real question is what is the best way to terminate parallel 4/0's onto a 200 amp meter/main?.
