Parallel conductors
lauraj
Portland, Oregon
Purely theoretical question here:
If you are installing isolated phase parallel conductors in conduit as permitted by 300.3(B)(1) exception into a metal bottomed enclosure, you have to cut a slot between the conduits per 300.20(B).
What about the metal locknut? Does that act as an inductive choke?
Re: Parallel conductors
The two times I have been directly involved in isolated phase arraignments as described in 300.20(B) Exception we did not use lock nuts.
I can not imagine using that exception in combination with metal bottomed enclosures.
The exception only applies to underground conductors which IMO suggests open bottomed switchgear will be the only option.
I agree with Iwire, the times I have done this type of underground installation, it has always been in open bottom gear.
In a metal bottom enclosure you could use aluminum locknuts or a PVC chase nipple into a coupling for a couple of options.
Roger
I agree with Roger's agreeing with Iwire. :)
To elaborate on what Roger said regarding aluminum locknuts, you could use any locknut that is non-ferrous (no iron).
I also have installed this type of installation, but never to a metal bottom enclosure.
I guess I would probably have cut the bottom out of that enclosure.
I would also look at the installation instructions for that enclosure, sometimes you will see it says "top feed only". We have just such a scenario from a fair sized job here. The pipes are already installed underground, and I was reading the installation instructions for the equipment and it says "top feed only".
What a surprise... they were not happy I found that.
