I'm lookin' at 300.20(A) and I'm thinkin' and I'm lookin' and thinkin' and I see the word "grouped" and I see the wording in (B), I'm thinking that the distance between conductors is an issue because of the magnetic field. . And where the fields overlap between hot and neutral, they cancel each other. . So if the wires are close together but not in physical insulation to insulation contact, I imagine that there is a small portion of the field that isn't canceled.
If that's true then I would think that the distance between the conductors would need to be less than the distance between a conductor and any nearby metal part of any kind.
And if I'm wrong, I'll claim that I wasn't actually wrong, but that you misquoted me :roll:
David
