ohmhead
- ORLANDO FLA
Well   as a electrician with a  limited electrical education i need help ?
What i think Skin Effect is
skin effect is current pushed by the magnetic flux induced in the center of the conductor by its own self magnetic force as current flows in it .
Now the current is limited to the outer surface area of that conductor which now limits its rated current flow and heat ,reactance and ac resistance is the product of this .
What i think Proximity Effect is
proximity effect is worst case its when two or more conductors run in parallel next to each other and are of the same phase .
Its effects now are the same as the above effects but now the current flowing in both conductors in the same direction is pushed to the outer surface but with more force and current is now limited to just half the surface area of the single conductor of the outer shell .
I know buss ducks and buss bars are run like this but the surface area of a rectangular bar or buss is more surface area then a round conductor .
If more heat and reactance is a problem with parallel same phase conductors why do we do it i always tought by installing all phases in one conduit it was a better installation ?
