This question is regarding a new installation that didn't look right. The building has a 600amp 3phase 408/277V service. The slab was originally roughed in with 2-3.5" pvc conduits. It was discovered that one of the conduits had an impass. The single 3.5" conduit now contains 6-phase conductors, 2-neutral conductors, and 2-grounding conductors. The conduit is not overfilled and the derating factors work out OK.
My question is this; can the parallel feeders from the service disconnect to the main distibution panel in the building be in the same conduit per NEC?
