discusted electrician
I have a 1500KVA xmfr (utility owned) supplying power to a 4000A MDP. The main feeders are underground in PVC pipe and consist of 10 conduits. The MDP is three phase. Each of the ten PVC conduits consist of just three hots and a neutral. Their is no ground in any of the ten conduits from the MDP to the xmfr. The MDP is not connected to a grounding electrode system, but is connected to building steel by means of a 3/0 copper. Since the neutral from the MDP back to the xmfr is being used as a egc, could this cause harmonic distortion and would pulling a seperate ground in all ten conduits from the MDP back to the xmfr cure this problem?
