Barbqranch
- Arcata, CA
- Plant maintenance electrician Semi-retired
We have two 15hp air compressors, both fed from the same subpanel. Each has what I believe is an appropriate sized ground wire (I can't see the printing). There is also an A-B panel to control which one has priority.
In the wiring to the A-B panel, there is also a (12 gauge) ground wire, creating a parallel path to the larger wire in the main compressor power feed. Is this OK? I wouldn't bring this up if I thought it was, but I am not sure.
Thanks.
Thanks.
