Came across a situation today and was wonder what your thoughts were on this.
Aside from an absolute mess, what would you refer to this as: paralleled neutral, shared neutral, or something else entirely?
Note: This is confusing, even when looking at it.
2 12/2's leave a panel and each hit a time clock. From the time clocks, 2 more 12/2's (load side) leave the time clocks and enter a junction box. Inside the jbox, the 12/2's connect to two 12/3's in this manner: the neutrals are tied together and the black from the 12/2's are connected to the red on the 12-3's. Those two 12/3's come from the panel where the blacks are landed on breakers and the reds are spliced with 2 the red's from 4 other 12/3's (one red from the jbox 12/3's are spliced with two other red's in the panel.) The blacks from the other 4 12/3's are also landed on breakers. All the neutrals are tied in to the neutral bar at the panel. Back at the jbox, the black from the 12/'3's are tied with the blacks from two more 12/3's, the neutrals are tied with the neutrals from the two additional 12/3's, and the reds from those additional 12/3's are connected to the blacks of two more 12/2's coming from the panel, and all the neutrals are tied together. No two pole breakers were used, no handle ties were used, but this is a much older instal and it's a possibility that this was a multiwire branch circuit venture gone horribly awry. It looks like they just pulled neutrals from anywhere possible and ended up mixing and matching neutrals from as many as 4 circuits at one time.
Needless to say, I didn't want to be the last one to touch this. I told the customer that unless they wanted to pay me to completely rewire these circuits, I would not touch anything on them or add anything to them. Good call I think.
Any thoughts on what this mess would actually be called or referred to by the NEC would be greatly appreciated.
Thanks
Thanks
