Tbatson44
- Springfield, MO
I am new to work on installing transformers. I've listened to Mike Holt's stuff and tried to pay close attention, although much is still over my head. My question is on the grounding video. He goes through parallel paths to ground. I am looking at a diagram for corner bonded delta. Phase C in this case is gray wire going into the plant and same with the EGC. Can someone explain in easy terms why this isn't parallel paths? Thank you.
