DooCrewRacing
- Sanford
If I had a meterbase 500' away from my first means of disconnect.....
#1 The meterbase requires a ground rod (I guess for utillity transformer ground/bond)
#2 The distance to the first means of disconnect being 500' (and where bonding should take place) gets a ground rod and neutral bonded
Question presented is : Would a equiptment grounding conductor be required?
and if so, would that be parallel paths to ground?:-?
