We have 2 sets of 3C # 4/0 parallel feeders with a # 4 ground, This is tray rated cable with a 400 amp fused OCPD. This feeds a 150 hp exhaust fan. Typical for 3 fans.
The cable is standard built with the # 4 ground, to get a larger ground would require a special ordered cable. Per code it should be a # 3 ground in each cable.
is there a way to add supplemental grounding. I.E., pulling another cable in the tray to each fan or can the tray be calculated and considered supplemental.
Thanks in advance for your help.
