jselesk2
- Cleveland, Ohio
Hello,
The information I've found seems to be conflicting regarding this topic. Let me give a simple example - a circuit supplied by a 20 amp breaker is wired with 12 guage wire. It supplies several outlets and lighting fixtures. Suppose that somewhere along the circuit, 14 gauge wire is paralleled off the 12 gauge wire to supply a single 60 watt light bulb. Is this allowed? If not, why? Seems perfectly fine to me because the 14 gauge wire in this case will only draw as much current as the light bulb, which is far less than 15 amps.
