Paralleling breaker protected main panel feeders
Paul_NJ
New User
New Jersey
Retired
This may have been addressed before: forgive me if I missed it.
I am seeking to replace and upgrade the subpanel in an old farmhouse. I already installed a new 200 amp main. Now seeking to increase it's subpanel capacity from 50 to 100 amps and wish to keep the AWG 6 wire already in place, and just add another set of feeder wires . I understand the purpose of NEC 310.10 is to address the possible hazards of paralleling two 50 amp capable conductors under a single 100 amp main panel breaker, where a conductor could find itself facing 100 amps and thereby under-protected due to any number of scenarios. But what if 2-double 50 amp main panel breakers feed conductor pairs that leave the main travel in separate conduit raceways to the subpanel, and are connected to the busbars there? Seems like each feeder conductor will be protected from ever seeing above 50 amps. And 100 amps will be delivered to the subpanel. Current only flows if a device plugged into the subpanel is taking it. Won't both subpanel legs draw as needed from the main, and all feeded conductors are protected at 50 amps. Isn’t this a different scenario from what 310.10 is addressing (feeder conductors are not protected unless the current hits 100 amps, well above it’s ampacity?). Sorry if I'm missing something . . . . .
All this to add more AWG 6 instead of replacing it all with AWG 2 . . . . saving $500 . . . .
Thanks for your help.
I am closing this thread, in accordance with the Forum’s rules.
This site is designed for:
Contractors
Electricians
Engineers
Inspectors
Instructors
This NEC Forum is for those in the electrical and related industries.
Forum rules prohibit us from assisting a person to perform or assist others to do electrical work who are not qualified. The reason is that the forum’s owner does not want a person to get an answer to the question they asked, but not get answers to the other questions they should have asked and were unaware they needed to ask. Mike Holt Enterprises and the Moderators of this Forum do not wish to place you and your family in danger, by allowing others to give you too little information to ensure that the installation is safe.
