b2000s81
- Orlando, FL - USA
How do I tie how to tie a PV system and a generator into a building supply if I am paralleling co-gen units and PV systems into a single building service?:?
Interconnect the PV outside the transfer switch or switches that connect the critical loads to the generator so that the PV and generator cannot be connected to each other.
Perfectly reasonable advice for a backup generator, but the OP is talking about co-gen, which is by nature grid interactive, just as grid tie PV is. With the notable difference that co-gen may normally not try to produce at its maximum output capacity at all times.
Co-gen which is designed to allow islanded operation switches to a voltage regulating operation mode when the grid is not present rather than synchronizing to the grid for both voltage and frequency. Part of the provision for islanded operation may involve load shedding to keep the connected load within the generator's capacity. And, of course, islanded operation will require either a simple transfer switch or a network protection relay to keep from backfeeding a "dead" grid. Actually, a simple ATS will not work in this situation, and instead a network protection relay or other backfeed detector would be required. That would not allow backfeed from PV if the PV were connected downstream of it. Does co-gen commonly involve net metering or does it always have backfeed prevention? If a particular co-gen installation can operate islanded with backfeed protection, one way to combine PV with that co-gen is to put the PV on the grid side of that protection, whatever form it may take.
But a more comprehensive approach would allow the PV to also contribute to islanded operation with a provision to throttle or disconnect the PV when the local load is less than the PV output, to avoid backfeeding the co-gen.
I think a little clarification is in order here. Co-generation has nothing to do with paralleling with another source. Rather it is producing 2 forms of energy with the same prime mover, typically electricity and heat. The OP is referring to grid interactive/paralleling of a POCO, genset and PV source. The genset may, or may not be a co-gen source. A co-gen system may not even connect to another source in many applications. I realize you probably get that, but co-gen is not the correct term.
