Hoping someone can help.
Existing conditions:
2000 ft ductbank
old feeder 4-500 kcmil in one duct
not so old feeder 4-500 kcmil in another duct
cable insulation type of feeders may not match
existing load has been demolished
New load is 150kVA, 480V, 3PH
I would like to parallel the two sets of existing feeders in order to reduce the voltage drop from about 5% (if one set were used) to about 2.5% (using both sets). Since the ampacity of one set of cables is not a limiting factor, I don't see why 310.10(H)(2)(4) would apply. Would paralleling the two feeders with different insulation types violate the code in this case? If so, why?
Thanks in advance.
2000 ft ductbank
Thanks in advance.
