Re: Paralleling of Transformers
You might want to look into "network protectors" as well. When you have two or more transformers in parallel, a fault within one could cause a failure of the second, unless there is protection in place. It is similar to a "reverse power relay," as is used when two or more generators are in parallel. If one transformer starts taking in large amounts of power from the remainder of the network, it is an indication of a failure, and the "network protector" opens the circuit from that transformer.
By the way, asking us to give you a complete instruction manual that tells you everything you need to know is a bit out of line. We can help with specific questions. We can point to information sources. But we won't do your job for you.
