Re: Paralleling utilities
You said "gen-sets" above so your scenario probably involves the paralleling gear to connect 2 or more gensets in parallel to achieve a larger power output. The gear would have the main section with all the controls, relaying, etc. and then a vertical section for each genset with a drawout breaker. You do this for redundancy, reliability and cost savings. For example it could be cheaper to buy (2) 1MW gensets with gear instead of (1) 2MW genset. Also, if that big unit fails you have no backup power available. If one of the smaller units fails you can shed load and still stay online with critical systems.
Often times they want the whole setup to also parallel with utility for peak shaving applications. During high demand (high cost) times they can power most of their load with the gensets and only buy what they need from the utility. Off peak times they can do the opposite or run on utility alone.
