electrics, I'm trying to understand your operating situation more clearly.
Are you wanting to operate in parallel all the time, or only momentarily when you switch from one transformer to the other?
I will reserve further comments until I can understand your situation better.
I know this question dates a while back, but I have a similar situation. The following transformers are in parallel. They are continuously operating. The are feed by a single source, being the utility incoming.
XFMR 1:
2500/3125 FFA
43800 PRI
2520 x 5040 DELTA / 4360 y x 8720 y SEC
6.5 %Z
TAP A (46200)
XFMR 2:
2500/3125 FFA
24000 x 48000 PRI
2500 x 5000 DELTA / 4330 y x 8660 y SEC
6.3 %Z
TAP B (46000)
Question:>
How can I find out the effects of circulating current on the load?
How much circulating current I should expect?
If operating at Full Load will the circulating current disappear?
I have a program called PTW*SKM. I am able to simulate the power flow on these two transformers but I cannot seem to find a way to show that circulating current.
Thanks.
