Parelled cables and step distance relaying
mbrooke
Batteries Included
United States
Technician
Can paralleled cables (242kv XLPE, 1,500cu) be protected via a single CT or does each cable need its own CT? I'm thinking that theoretically it will work if the impedance is set to account for only one cable, however I am not sure if mutual coupling will cause over or under reaching. Each 3 phase set is cross bounded on the ground shield and each phase in its own conduit.
