mbrooke
Batteries Included
- United States
- Technician
How is this typical done in the industry? Presently the plan is to parallel 3 750kva 12.47 Delta-480 wye units to a single collector buss. All 3 will be fed from the same primary feeder under any contingency thus phase angles will be identical. Primary protection is via bayonet fuses integral to the pad but can be supplemented via S&C PME switch-gear protective package add on, however the secondary protection (if at all) is up in the air.
