I am working with Parking/Storage garages in a condominium high-rise that is used for tenant parking/storage and has closed off equipment rooms within the garage levels. Per NEC2002 article 511, is it true that the receptacles within parking/storage areas don't require GFCI protection but the closed off equipment rooms do require GFCI protection? Since the garage includes rooms with equipment I wasn't for sure if you could break down the garage into separate classifications.
Thanks,
David-St. Louis,MO
Thanks,
David-St. Louis,MO
