Re: parking lot lighting 2
It really depends on many factors, including what type of facility you are talking about, what type of room in that facility, what light levels you want to achieve, and what the energy codes will allow you to install. NEC Table 220.3(A) gives you the minimum watts per square foot for various types of occupancies. But it?s purpose is to make sure the utility provides enough power to the whole building, not to achieve a minimal lighting level.
Lighting manufacturers will often provide you with a calculator that you can use to select one of their products, lay out the lighting pattern, and calculate the lighting levels at various heights above the floor.
